Generate standard centroid file?
eric_engineer
eric_engineer
Is there a way to generate a standard centroid file for pick and place?  That's usually:
RefDes, Layer, LocationX, LocationY, Rotation
The PickandPlace button made something close but it's putting the footprint name first and the refdes last.
Tahnk you
jorge_garcia
Hi @eric_engineer ,
I hope you're doing well. There are several ULPs that can be used for centroid export.  Besides the one you tried, if you go into the ULPs that ship with Fusion 360 there is a screaming circuits one that should give you what you need. Additionally, you can take the output you currently have and bring it into excel, swap the columns and then re-export it.
Let me know if you continue to run into problems.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
