Fusion PCB max trace length BUG
danielfrenkel
danielfrenkel
I'm working on a PCB heater, and have been struggling for hours with an issue.
After a trace reaches the length of 6713.949 mm, the trace length suddenly becomes negative and begins to subtract from the total distance. So if I add 100mm more after 6713.949, it'll show as -6613.949
The length is critical for me and this bug is making it impossible to lay out my heater.
Thank you
jorge_garcia
Hi @danielfrenkel,
I hope you're doing well. Would you be willing to share the files for review? They would not leave Autodesk and would only be used to diagnose the bug.
In the meantime, try using the Meander command to measure the length maybe it doesn't display the same issue.
I'll send you my e-mail through DM.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
