Fusion isn't paying attention to polygon pours when running ratsnest
ronDWTRR
Message 1 of 10
ronDWTRR
I've recently imported an old Eagle PCB file into Fusion, and I'm running into an issue. This is a 4 layer board, with ground and power planes in layers 2 & 3 respectively. Fusion doesn't seem to recognize these layers when running a ratsnest. All ground and power vias that should be connected through the inner layers end up with airwires.
I found a post here about the "Ratsnest processes polygons" setting, but the only difference is that, when the setting is turned off, ratsnest reports "378 airwires (Eagle rc setting prevents Ratsnest from filling Poly Pours)". When the setting is turned on, ratsnest reports "378 airwires" with no further text.
Is there some other setting I'm missing? This board has always been ok in Eagle.
Replies (9)
Message 2 of 10
jorge_garcia
Hi @ronDWTRR,
I hope you're doing well. Ratsnest isn't really necessary in Fusion like it was in EAGLE. See the image
Use the show all polygons, refill polygons, etc. commands instead and see if this solves it.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 3 of 10
ronDWTRR
Show/hide polygons was the first thing I tried, I only went to ratsnest when those didn't work. Neither resolves the airwires, unfortunately.
Message 4 of 10
jorge_garcia
Hello @ronDWTRR ,
I hope you're doing well. Would you be willing to share the files for review? I'll DM you my email so you can send them to me for review.
Best Regards,
Jorge Garcia
Message 5 of 10
ronDWTRR
The Share Link menu item is grayed out on all of the board files, is there another way I can share them? (Or, how do I get access to the Share Link option?)
Message 6 of 10
ronDWTRR
I should also mention that this is happening in another one of my projects now.
Message 7 of 10
ronDWTRR
Scratch that last message, it's only happening on one project.
Message 8 of 10
jorge_garcia
Hi @ronDWTRR ,
By chance are the airwires hidden? Try Ratsnest * in the CLI and then refill the polygons.
Best Regards,
Jorge Garcia
Message 9 of 10
jorge_garcia
Hi @ronDWTRR ,
Just posting here in case someone else runs into it. The issue was that for some reason the layer stackup had switched to a 2 layer board, hence it wasn't taking the 2 inner layers into account. That's why all the airwires cropped up.
Best Regards,
Jorge Garcia
Message 10 of 10
ronDWTRR
Thanks Jorge!
