FUSION 360 schematic net connection issue
yuzhou.lei
yuzhou.lei
there are some warnings after I do the ERC check, which are "SEGMENT OF NET HAS TO VISUAL CONNECTION TO OTHER SEGMENT OF SAME NET"
the warnings:
what does this mean?
yuzhou.lei
more inforamtion,
I checked the PCB, it looks ok.
Can I just approved these?
yuzhou.lei
no one met this kind of """"issue before?
constantin.popescuXD3CL
Hi @yuzhou.lei,
It most likely means that you haven't named the net segment explicitly (using a Net Label object) or there is no supply pin (VCC, GND, etc.) that would name the net automatically or the net segment is not connected to a bus. If you post a snapshot with where the issue is in your design I might be able to have a more precise answer.
I hope this helps.
Kind Regards,
Constantin Popescu
Principal Software Engineer
