Fusion 360 Crashing on Start Up
RCBakerBorn
Message 1 of 23
RCBakerBorn
I have been off work for a week.
I came back and tried to open Fusion 360 a half dozen times, only to see this dialog box every time.
Is Fusion 360 down again?
Replies (22)
Message 2 of 23
RajkumarIlanchelian
@RCBakerBorn Can you please submit these reports and you should get a report ID. please paste the report ID here.
Also, you can run the Fusion service utility and run a repair Fusion 360 to see if that helps.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 23
RCBakerBorn
I do not get a report ID. I get this.
Below is a speed test for the network.
Message 4 of 23
RCBakerBorn
Trying to run Repair Fusion 360 now.
Message 5 of 23
RCBakerBorn
... not responding...
Message 6 of 23
RCBakerBorn
Now
Message 7 of 23
RCBakerBorn
Updates
Message 8 of 23
RajkumarIlanchelian
@RCBakerBorn Looks like a permission error. Can you follow the guidelines from this article?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Fusion-360-WinErro...
Autodesk Fusion
Join Fusion Insider
Message 9 of 23
RCBakerBorn
These are the current security settings. It looks like there is full access for everyone.
Message 10 of 23
RCBakerBorn
More Information for diagnosing maybe?
Message 11 of 23
RajkumarIlanchelian
@RCBakerBorn Thanks for the log files. Taking a look now.
Autodesk Fusion
Join Fusion Insider
Message 12 of 23
RajkumarIlanchelian
@RCBakerBorn The logs shows that you are on build 2.0.16265 which is from last year. Can you please do the below for me?
1. Close Fusion 360
2. Delete the shortcut that you are using to launch Fusion 360 (Important)
3. Go to Add/remove Programs - Select Fusion 360
4. Modify
5. This will launch the Fusion service utility
6. Uninstall Fusion 360/Re-install Fusion 360
7. This will take you to the latest version
8. This will also generate a new shortcut that you can use for launching the program
This should take you to the latest 2.0.16490 and this should get you moving forward.
Autodesk Fusion
Join Fusion Insider
Message 13 of 23
RCBakerBorn
Hey Rajkumar,
I deleted the shortcut
I went to Add/Remove programs/Fusion 360, and clicked on Modify
The Service utility opened
I only see Uninstall Fusion 360 in the service utility
There is no Uninstall/Install in the service utility
Will Fusion 360 automatically install when uninstall is done?
Message 14 of 23
RCBakerBorn
I tried Uninstall from the Fusion 360 Service utility Menu and it says (not responding)
Then when i click again, it asks if I want to close the program.
I clicked on the wait for program to respond several times and it keeps popping back up. So I close it.
Message 15 of 23
RajkumarIlanchelian
@RCBakerBorn In the service utility can you run the Repair Fusion 360?
Autodesk Fusion
Join Fusion Insider
Message 16 of 23
RCBakerBorn
When I try to do that is also says not responding. Then it repeats the same dialog box as trying to uninstall.
Message 17 of 23
RCBakerBorn
When I try to uninstall from the add/remove apps menu I get this.
Message 18 of 23
RajkumarIlanchelian
@RCBakerBorn One more thing to try out is to restart the machine and then do the repair. Wondering if there are multiple exes running in the background. If this does not work, then I have another option to try out.
Autodesk Fusion
Join Fusion Insider
Message 19 of 23
RCBakerBorn
So the program is uninstalled. But no auto install.
Do we download fresh from Autodesk's website?
Message 20 of 23
RajkumarIlanchelian
@RCBakerBorn The repair does an automatic install as well. If you have manually uninstalled then yes you have to install the product again.
Autodesk Fusion
Join Fusion Insider
