Footprint editor route16 as bottom
j_r0dd
Message 1 of 19
j_r0dd
So I just noticed that the Restrict Layers dropdown in the footprint editor is thinking that route16 is the bottom layer, so it doesn't go through the whole stack. I don't know if this is from the recent update deprecating the restrict bottom layer or what...
Replies (18)
Message 2 of 19
jorge_garcia
Hi @j_r0dd ,
I hope this message finds you well. Is this a brand new footprint or an existing one?
Try this, go to the electronics CLI and type upgradelayers and press enter. Do you still see c16 as the bottom?
Best Regards,
​Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Message 3 of 19
j_r0dd
It says upgrade layers can only be ran in the schematic or pcb editor. When I run in either of those it says I already have extended layers. So my existing libraries show RestrictTop with c16 as the bottom. If I create a new library I do get RestrictCopper, but c16 is still the bottom
Message 4 of 19
jorge_garcia
Hi @j_r0dd ,
Could you give me a procedure of how you are getting the inspector to show this? I just tried with the Restrictarea command and it shows the correct layers on an existing component.
I'm trying to reproduce your issue to be able to share it with the developers.
Let me know if there's anything else I can do for you.
Best Regards,
​Jorge Garcia
Message 5 of 19
j_r0dd
I attached a screen recording. I am on MacOS btw. I tried running the service utility and reinstalling. Nothing made a difference.
(view in My Videos)
Message 6 of 19
jorge_garcia
Hello @j_r0dd ,
I hope you're doing well. I can't reproduce this on Windows so I have asked our QA team to see if they can duplicate it. It might be the case that this is a Mac only issue.
Best Regards,
​Jorge Garcia
Message 7 of 19
j_r0dd
Just wanted to see if they were able to duplicate this.
Message 8 of 19
jorge_garcia
Hey @j_r0dd ,
We have not been able to duplicate this. Do you have any other info you could provide? Are you on the latest Fusion release?
I've tried and QA has tried as well, so far we can't get this.
Best Regards,
​Jorge Garcia
Message 9 of 19
AlinaPeng
Hi @j_r0dd ,
I hope you're doing well. Thank you for the screen recording. It was very helpful.
Unfortunately, we still haven't been able to reproduce the issue on our side. To help us investigate the root cause, we'd really appreciate your help with a couple of things:
1. Could you export and share the newly created library as a .flbr file? We would like to inspect the actual file to see how the layer is stored internally. In particular, we're looking for the newly created library from your recording, where the bottom layer is displayed as c16 Route16 instead of cb Bottom.
2. Could you share a screenshot of the Display Layers panel? While the affected footprint is open, could you open the Display Layers panel and send us a screenshot? That will help us understand how the layers are set up on your side.
I'd also like to confirm one detail. From the video, it looks like the issue first appeared in an existing footprint and then continued to occur even after you created a new library. Is that correct? If you restart Fusion and immediately create a brand-new library, does the issue still occur?
Thank you for your patience and cooperation. We look forward to hearing from you.
Best Regards,
Alina Peng
SQA Engineer
Message 10 of 19
Closed-Loop-Bot
Thanks for bringing this to our attention. We're investigating the issue, and you can reference ticket FUS-263200 when communicating with Autodesk to find out more. Once the status of this will change, there will be a follow-up forum post made.
Message 11 of 19
j_r0dd
@jorge_garcia I'm on the latest and did a full purge everything Autodesk related and reinstalled.
@AlinaPeng I attached a newly created library right after opening fusion and included an older library, like maybe 2-3 months old. Even if there are smd pads on the bottom layer in the footprint editor, cb Bottom does not show in used layers. I'm only using the default layers when the footprint editor opens. I usually switch to UsedLayers , but if the footprint has pads on both layers then I have to use AllLayers for the bottom ones to display and the Inspector shows they are on cb Bottom. The only time I can even get RestrictCopper to show is with a new library and even then if I draw something on that layer and go to the inspector to add the bottom layer, I only get c16. If you need anything else from me I'll provide.
Message 12 of 19
AlinaPeng
Hi @j_r0dd
Thanks for sharing the detailed information, the library, and the screen recording. They were very helpful.
We've fixed this issue in our latest insider build. If you'd like to try the fix before it's included in a public release, you can apply for the Insider program here: https://feedback.autodesk.com/key/Fusion360Insider .
Just note that the Insider program isn't instant access and does require signing an NDA. If you'd rather wait, that's completely fine. The fix will be included in an upcoming public release.
Once it's available, I'll update this thread so you can check whether the issue is resolved in the released version.
If you decide to try the Insider build, please let us know whether you still see the issue.
Thanks again for taking the time to provide all the details.
Best Regards,
Alina Peng
SQA Engineer
Message 13 of 19
jr0dd
Observer
Observer
I appreciate it and as tempting as that sounds, having done QA work in the past, I would probably drive you all crazy lol. I prefer to stay oblivious for now unless something super critical crosses my path.
Message 14 of 19
Closed-Loop-Bot
We're happy to report this issue has been resolved. Update Fusion to the most recent version to apply the fix. If this update resolved your issue, feel free to click the "Accept Solution" button to help other community members find the answer more easily. If the issue persists after updating, don't hesitate to reach out to us by replying to this thread. We're here to help! Let us know if you need any further assistance!
Message 15 of 19
jr0dd
Observer
Observer
I still have c16 showing up as the bottom layer in existing and a new library creation...
Message 16 of 19
stefan_schreiter
Not Solved!
use import-bmp.ulp
Select Layer 16 to import
now it shows cb16 Route16
then upgradelayers dose nothing.
Message 17 of 19
jorge_garcia
Hi @stefan_schreiter ,
Do not use layer 16 to import into new designs. You should only import into the new cb bottom layer (I think internally its is 304). If you import into layer 16 then now you are creating a new layer which isn't the official bottom layer anymore.
Best Regards,
​Jorge Garcia
Message 18 of 19
stefan_schreiter
Haven't found Which layer which ID is, whether its bad documented or not documented at all.
Message 19 of 19
jorge_garcia
I hope you're doing well. Which layer ID are you asking about? If it's bottom it's layer 304 internally. If it's something else let me know.
Best Regards,
​Jorge Garcia
