Hi @j_r0dd ,
I hope you're doing well. Thank you for the screen recording. It was very helpful.
Unfortunately, we still haven't been able to reproduce the issue on our side. To help us investigate the root cause, we'd really appreciate your help with a couple of things:
1. Could you export and share the newly created library as a .flbr file? We would like to inspect the actual file to see how the layer is stored internally. In particular, we're looking for the newly created library from your recording, where the bottom layer is displayed as c16 Route16 instead of cb Bottom.
2. Could you share a screenshot of the Display Layers panel? While the affected footprint is open, could you open the Display Layers panel and send us a screenshot? That will help us understand how the layers are set up on your side.
I'd also like to confirm one detail. From the video, it looks like the issue first appeared in an existing footprint and then continued to occur even after you created a new library. Is that correct? If you restart Fusion and immediately create a brand-new library, does the issue still occur?
Thank you for your patience and cooperation. We look forward to hearing from you.
Best Regards,
Alina Peng
SQA Engineer
