Fail to upload library to LIBRARY.IO
- Mute
- Permalink
- Report
When I try to upload a certain library to LIBRARY.IO, I get this error :
Échec de l'importation de la bibliothèque gérée (La transaction a échoué: Error transferring https://contapi.circuits.io/123D-Circuits/libraries/16378166/import - server replied: Forbidden).
Si ce problème persiste, veuillez contacter le support technique et spécifier l'URN de la bibliothèque: urn:adsk.eagle:library:16378166.
Best regards
EDIT : I was able to upload the library with Eagle.
EDIT2: I had to unlink the library on Fusion 360 first and after that I was able to upload the library from Fusion 360 to LIBRARY.IO. So problem solved.
EDIT3 : The same trick didn't work with another library, I get this error :
Échec de l'importation de la bibliothèque gérée (failed).
Si ce problème persiste, veuillez contacter le support technique et spécifier l'URN de la bibliothèque: urn:adsk.eagle:library:22558159.
