EXPORTSTEP command not working
lars.kvandal4V2DJ
lars.kvandal4V2DJ
I am making an export script for PCB's. When i try too use the EXPORTSTEP command nothing seems to be happening. Is there something wrong with the command or am i doing somthing wrong?
jorge_garcia
Hi @lars.kvandal4V2DJ,
I hope you're doing well. The EXPORTSTEP command was something that worked in EAGLE and depended on the existence of the Control Panel which Fusion does not have. I've put in a defect report so that this can be sorted. In the meantime you have to use Fusion's normal STEP export options.
See this article for more info
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-export-spec...
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
