export by script
export by script
matthias_henkel
export by script
matthias_henkel
Hi want to make a local backup of my fusion electronic circuits, boards and libraries with a script.
I already done this with my 3D components by using
export_manager.createFusionArchiveExportOptions(file_path)
export_manager.createSTEPExportOptions(file_path, component)
How can I do this with the fprj, flbr, fbrd, fsch file extensions? Is there a function for, like above.
Accepted solutions (3)
jorge_garcia
Hi @matthias_henkel,
Ideally you would run something like that from the Electronics Design file. Doing it from the electronics design file will make sure you get the schematic, board and 3D PCBs get exported together. I know that Electronics objects are not yet incorporated into the Fusion Python API so it might not work.
I'll run this by our PM who used to write lots of scripts she might have a better idea of how this would work.
Best Regards,
​Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
devY8D5P
@jorge_garcia What is the condition of it? When will the export be ready? Is there a way how to backup my fusion electronic circuits, boards and libraries with a script? Thank you
jorge_garcia
Hi @devY8D5P,
I hope you're doing well. Unfortunately, I don't have an ETA for this. I'll bump it up again to our developers for review.
Let me know if there's anything else I can do for you.
Best Regards,
​Jorge Garcia
JohnLauer_Adom
FWIW, I'd like to bump this feature request higher. I've spent a ton of time over the last few weeks trying to figure out how to export .brd and .sch files and it's failing. We really need a real export API here. It's not even that hard of a request since the export is there for the user to manually trigger. The closest I've gotten is to find the temp Electron folder and search it for the .brd and .sch file. However, this isn't perfect because when the user saves a new version of their .brd or .sch file, it doesn't seem to regenerate a new temp folder file. So, you end up having to give the user an option to close and then reopen their Fusion 360 electronics board and schematic document just to force it, which is super janky.
The other thing I've tried is to almost recreate from scratch, via ULP's, the .brd file format, but this is not fun and unlikely will be able to easily/perfectly match the .brd file format. So far I've maybe gotten 80% close, but this sure is a ton of work that is very fragile.
Why this is so important to us, btw, is that we are building an electronics prototyping factory in the U.S. and we want to allow users to design electronics for it using Fusion 360 and be able to easily export them to our cloud software to use our factory.
John Lauer, CEO, Adom Industries | Fusion bridge (free, open source): wiki.adom.inc/adom/fusion-bridge
jorge_garcia
Hi @JohnLauer_Adom ,
I hope you're doing well. I'm 100% with you and I'm pushing for full Electronics support in the Fusion API.
Your use case is definitely something important to us, I'll pass this along to our devs and product management team for review.
Best Regards,
​Jorge Garcia
m.neumair
I would also like to push this feature!
