Expanded polygons
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have some parts in my library.io libraries that have tiny filled polygons in the tPlace layer. This has always rendered perfectly fine in Eagle but If I use the same parts in Fusion 360, the polygons expand quite a bit.
Screenshot from Eagle:
Screenshot from Fusion:
I don't know if it's the edge width or something else that behaves differently. The edge width property is not visible in the inspector in Fusion 360 at all. If I select a line it doesn't look any wider than it does in Eagle but it seems to be in the wrong place.
This is not a big problem for larger polygons but if you try to do silkscreen graphics with fine details, this ruins it completely.
I'd like to remember that Fusion 360 didn't have this problem initially but I'm not sure. It's been a problem for quite some time now anyway. Just haven't had the time to investigate why my silkscreen graphics look so bad.
I have to export my boards to Eagle and insert any silkscreen graphics from there and then generate gerbers from Eagle but I'd like to avoid using different applications for different tasks.
Is there anything that can be done about this behavior?
Per
