Exclude component from BOM
silvio3105
Message 1 of 9
silvio3105
Sometimes I have component that I don't want to see in BOM, like test points.
How to tell F3E - don't include that component in BOM?
Thanks!
Replies (8)
Message 2 of 9
panpan_fan
Hi @silvio3105
I hope you are doing well!
For Exclude component from BOM, you can create variant firstly and then uncheck the parts you don't want to show.
And then you need to select the variant you make when you Save BOM file
Please have a try to see if it works for you.
Panpan Fan
Message 3 of 9
silvio3105
I found that solution. Creating a variant just to exclude screw holes, visuals(logos etc.) is really stupid way to solve this.
New library workflow is WIP, right?
If yes, mark this as feature request for new workflow.
Message 4 of 9
panpan_fan
Hi @silvio3105
Would you mind describing more about the workflow you want?
I will bring it to the develop team to see if we can do some improvement for it.
Thanks in advance!
Panpan Fan
Message 5 of 9
silvio3105
Just add option for every device/component(no matter what footprint) to set do you want that component in BOM.
I guess F3E exports VCC and GND marks to BOM also.
Message 6 of 9
silvio3105
Message 7 of 9
jorge_garcia
Hi @silvio3105 ,
So just to clarify the default BOM ulp (that's what the current system uses) will exclude any devices that don't have packages and if my memory serves any devices that don't have copper in their packages. So supply symbols are automatically excluded, as well as logos that are just on silkscreen.
This feature will likely be implemented once we have a built-in BOM system and are no longer reliant on the BOM ulp. I'll log it.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 8 of 9
gwagnerJXG2J
+1 for a component "NO BOM" option
I have a couple packages with no copper ... ie silkscreen only for location markers that show up in the bom and I manually strip them later.
Layer ladder, and the pcb name in copper do have copper but no actual parts ... so end up stripping them from the bom later as well.
For arguments sake I do have variants, so unticked the population option for all of these.  Result is that the BOM is clean, but printing the Variant schematic I have a whole bunch of large "X" through the schematic symbols for those elements ... which isn't accurate either.
BR,
-- Glenn
Message 9 of 9
jorge_garcia
Hi @gwagnerJXG2J,
I'll add your comments to the existing request for improved functionality in the electronics BOM.
Best Regards,
Jorge Garcia
