Drill Legend ULP does not work?
eric_engineer
eric_engineer
I have a simple board. I tried to run the Drill Legend ULP command.  It starts throwing errors about layer 51 right away.  Then the first few times it lept from my pcb into a library I had open and created the drill drawing there.  With a bunch of popup errors.
I closed the library and tried to run the ULP again, same types of errors only this time it created nothing.  Does drill drawing just not work?
Also is there a similar tool for a stackup drawing or do I have to do it manually?
Thank you.
eric_engineer
I was able to get this to work (by magic? luck?  Not sure).
