DRC errors centering is not working on flipped board
ledvina
Message 1 of 8
ledvina
DRC 'ERRORS' with 'Centered' enabled is selecting wrong location when board is flipped.
This will jump farther and farther from PCB in some cases (high zoom, switch between DRC errors)
Replies (7)
Message 2 of 8
jorge_garcia
Hello @ledvina ,
I hope you are doing well. I've tried to reproduce this with a few files but I'm not getting it. Do you have an example file you could share? When I try it, the errors go to the correct places even if the board is flipped. I am using the centered option checked.
Let me know if there's anything else I can do for you.
Best Regards,
​Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 3 of 8
ledvina
Hello Jorge,
I'm sorry, the description was poor/incomplete.
Flip board (it offset from origin in my case) and zoom in so that next error is outside of current view. Then switch between DRC errors. Black rectangle is displayed correctly, but viewport is set to wrong position. Double-clicking error does set viewport correctly.
Message 4 of 8
jorge_garcia
Hi @ledvina ,
I hope you're doing well. When you say the board is offset, do you mean it's bottom left corner is not on the origin? I feel this might be an important detail. Thank you for the written description. If you have a moment and can record a screen capture that would be helpful.
Best Regards,
​Jorge Garcia
Message 5 of 8
ledvina
Hi Jorge,
Here is simple test board: https://a360.co/4rGhuCu
Zoom in to one set of vias with board flipped and click different errors repeatedly (switching between errors in different groups seems to make it worse). After few clicks, viewport starts to drift from error frame.
Petr
Message 6 of 8
lauri_barnhart
Hi @ledvina,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Lauri | Community Manager
Message 7 of 8
jorge_garcia
Hello @ledvina ,
Thank you for this sample file. I was able to reproduce the behavior, thank you for the excellent example. I will create a bug report for this.
Best Regards,
​Jorge Garcia
Message 8 of 8
Closed-Loop-Bot
Thanks for bringing this to our attention. We're investigating the issue, and you can reference ticket FUS-228981 when communicating with Autodesk to find out more. Once the status of this will change, there will be a follow-up forum post made.
