DRC error unrouted
DRC error unrouted
isalabhi9999
Observer Observer
DRC error unrouted
isalabhi9999
Observer
Observer
i have routed all the traces and airwire still some unrouted airwire errors are generated in drc check. i have tried checking all the the nearby traces and also tried to isolate that part by hiding layer but still there are no airwires there.
do anyone knows about this issue ?
jorge_garcia
Hello @isalabhi9999 ,
I hope you're doing well. If you can post and image of what you are seeing this will help. By chance do you have any components rotated at a 45 degree angle? You might have some really short point airwires that are difficult to see. Sometimes just running the autorouter will take care of it.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
isalabhi9999
Observer
Observer
See in both of screenshots none of trace are visibile still unrouted error is there please help me out with this
isalabhi9999
Observer
Observer
update:-i have soughted the issue with the first error i.e first screenshot.
the second one is still an issue
jorge_garcia
Let's make sure you don't have any airwires hidden. In the Electronics CLI please type
RATSNEST *
and press the enter key. If you have any hidden airwires they should popup.
The second image airwire might come from a gap or island formed when the polygon is filled. Try filling in the polygons and check for the airwire again.
Let me know if you continue to run into problems.
Best Regards,
Jorge Garcia
