Hi @silvio3105 ,
Let's clear this up. @yiqiu.han is referring to the import button inside the library manager, because that's where your STANDARD library is missing. In the top right of the library manager there is a book icon, click it and select import Fusion Team library, then in the dialog that pops up select your STANDARD library.
If ever a library doesn't show up in the library manager that you think should be there, you can go to the icon and manually import it in.
Best Regards,
Jorge Garcia
Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
