Display component attribute on PCB
CaptainMJ
CaptainMJ
Hi All,
I have a terminalblock on my PCB and I would like to write 3-4 characters for each pin on the board like, GND, +12V, In1, In2 etc.. I tried adding that as attributes and also values to the component in PCB view, but i don't see it printed on the 3D PCB which means it wont be on the board. Is there a way to do this? Not necessarily using attributes.
Many thanks,
Marcus
Best Regards,
Marcus
engineeringNCMXB
Add the information at TEXT on the footprint.
To make it dynamic - you can tie it to an attribute by inserting a '>' before the name of the attribute.
>ATTRIBUTE
Fusion will replace 'ATTRIBUTE' with the value of the attribute.
Carlos Acosta
Factory400 - YouTube|Instagram
CaptainMJ
@engineeringNCMXB , thanks, ah yes I did see those '>' for the component name in the footprint, that all makes sense now!
Many thanks!
Best Regards,
Marcus
AutomaticRock
Hi @CaptainMJ ,
Can you tell me how you have managed to give each pin a description? I want to do the same thing, but I can't figure out how to do this with attributes?
Best regard,
Benno
