Design blocks - built-in functions
Valentin.Gros
Valentin.Gros
I was using Eagle. I don't find the same functions to create and manage design blocks in Fusion 360 Electronics. I think it is an very important part, with the following functions :
  • create design Block
  • modify design block
  • copy design block
  • update design block if libraries changed
ps : I read that we could do something with the command line but it is not very pratical
Thanks, best regards,
Valentin
jorge_garcia
Hi @Valentin.Gros ,
The Fusion implementation of Designblocks is still a work in progress  so for now the command line option is the best way forward until the next version of designblocks is released, this is an important part of Electronics so we are working to address these gaps.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
valentin.grosGQU6E
Community Visitor
Community Visitor
I'm glad to hear that you are working on it, thank you for your reply.
Best regards,
Valentin
jorge_garcia
Hi @valentin.grosGQU6E ,
I hope you're well. In the latest release of Fusion there's the insert Electronics Design button, under the place sub menu of the Design section.
For now this will allow you to place an existing Fusion 360 design as if it were a designblock.
Best Regards,
Jorge Garcia
