Delete all technologies / attribute sets
bast2R8CK
bast2R8CK
Please forgive if I mix up some of the names here, they are so confusing to me. But please do correct me.
I want to delete all technologies / attribute sets of all devices/components in a library using an ulp or scr script.
I know I can achieve this for a selected device/variant/package (?) by the following scr commands:
package variant_name
technology -*
But for that to work on all devices/variants/packages, I'd have to know all the variant names.
I know how to get them using an ulp script:
string Version = "0.0.0";
string fname;
fname = argv[0];
fname = filesetext(fname, ".scr");
output(fname, "wtD") {
    library(L) {
        L.devicesets(S) {
            S.devices(D) {
                string technologies[];
                int n = strsplit(technologies, D.technologies, ' ');
                for (int i = 0; i < n; i++) {
                    printf("device %s technology %s\n", D.name, technologies[i]);
However, I don't know how to then delete the technologies inside the ulp script.
Is there a way to achieve both (find out device/variant/package names and delete the technologies) using only one script?
jorge_garcia
Hi @bast2R8CK ,
I hope you're doing well. See the attached image
You can use the run-loop ulps to take your simple script and have it run through all the components in a library and then all of the libraries.
Let me know if this helps.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
bast2R8CK
OK, so I guess, it is not possible to achieve the task using only a single script.
I solved my problem using both, ULP and SCR: ULP to find out all the technologies and outputting the necessary SCR commands either to a file that is afterwards executed, or executing SCR commands when finishing the ULP script using the commands as argument for exit().
fisherket812
technology -*
string fname;
fname = argv[0];
    library(L) {
        L.devicesets(S) {
            S.devices(D) {
I genuinely wanted to share this because it really helped me streamline my workflow. Sometimes, these little tricks with scripts can save you so much time and effort, and I hope it might be useful for someone else too. Just like how wearable technology is transforming the sports world, combining these tools in unexpected ways can make a big difference in other industries as well. Again, here the article on wearable tech in sports, which I found really insightful
Using ULP to gather the necessary information and then passing it to an SCR script for deletion worked like a charm. It saved me so much time! I just wanted to thank you for sharing the solution, it really helped me understand how to approach the problem better. If anyone else is facing a similar issue, this method is definitely a great way to go about it!
