Defining PCB with existing schematic and 3D CAD model
Alexander_hassSVFPE
Observer Observer
Alexander_hassSVFPE
Observer
Observer
I am a beginner in Fusion (formerly used EAGLE) and I fail to understand how to correctly set up my project. I started with a 3D CAD design, where a housing and a PCB outline is already drawn. I also have a draft for a schematic that I made with EAGLE.
Since we now need to correctly place components that will need an opening in the housing, I wish to:
- import my schematic from EAGLE into Fusion
- import all related components (or libraries) into Fusion as well
- define the drawn PCB from the 3D CAD model as a PCB
- link this new PCB to my schematic
- be able to move components in the 3D CAD model and see the result in the PCB layout
I've tried multiple things and I feel like my project is not correctly set up. I do have a schematic, a PCB layout and a 3D model of the PCB. I also exported my related EAGLE components into a library and imported them, but somehow I now got two libraries with the same name in my design. I also can't load my 3D PCB into the housing's 3D CAD model.
I am open to start all the imports all over, so I kindly ask to give me a general tutorial on how to set up everything. Other tutorials always explain how to do that without existing schematic.
Thanks in advance.
jorge_garcia
Hi @Alexander_hassSVFPE ,
I hope you're doing well. Check out this series for how to bring designs in from EAGLE to Fusion.
https://www.youtube.com/playlist?list=PLmA_xUT-8UlL5wTsDLkXtj_nBwojmRf5b
Let me know if you continue to run into problems.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
