Dark theme: overwrite confirmation popup shows white text on white background during CAM export
paullevene
paullevene
Summary:
When exporting CAM files (Gerber/DXF) in dark theme, the overwrite confirmation dialog (“Files with these names already exist in this directory. Do you wish to replace them?”) renders with a white background and white text, making the message unreadable.
Environment:
  • OS: Windows 11
  • Theme: Dark
Steps to reproduce:
  1. Preferences → General → Theme = Dark.
  2. Go to Manufacture → CAM Processor.
  3. Export Gerber or DXF to a folder where files with the same names already exist.
  4. Observe the overwrite confirmation popup.
Actual result:
The dialog’s background is white and the text is also white, so the content is unreadable. Only the warning icon and buttons are partially visible.
Expected result:
The dialog should respect the dark theme (dark background with light text) or otherwise present high-contrast, readable text.
Impact:
Hard to confirm/cancel a potentially destructive action (overwriting files). Accessibility/readability issue.
Screenshot showing the issue (white-on-white dialog) attached.
jorge_garcia
Hello @paullevene ,
I hope you're doing well. Thank you for the report, our developers are working on this and I believe a fix has already been completed and should be coming shortly.
Thank you for the excellent posts.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
