Custom rule won't change space of differential pairs
aiolus2ZLRU
Message 1 of 16
aiolus2ZLRU
The custom rule doesn't work when routing differential pairs.
I'm trying to set the space of differential pair B0_P and B0_N and add a custom rule as below
The general rule was kept as below
After trying different scopes in custom rules, nothing affect the space of differential pair.
where the grid is 1mm, wire width is 0.254mm.
It only shows the violation of space, but the space parameter still follows general rule but not custom rule.
Please help to clarify if I'm missing any setting or how to control the space of differential pairs.
Replies (15)
Message 2 of 16
jorge_garcia
Hello @aiolus2ZLRU,
I hope you're doing well. Thanks for reporting this, we ran into this shortly before release the developers are already working on this one.
You are not doing anything wrong it's just not working right now. I'm hopeful that by the next release this will be sorted, can't promise it but I have a good feeling about it.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 3 of 16
jorge_garcia
Just to investigate further, did you create the rule after the diff pair was already routed? It won't update the routing automatically.
Jorge Garcia
Message 4 of 16
aiolus2ZLRU
No, I always modify the design rule before routing.
I just had a tried, custom rule for differential pairs is working now. Thanks for your quick response.
Message 5 of 16
constantin.popescuXD3CL
Hi @aiolus2ZLRU,
Good to hear the diff-pair routing is now using the custom rule. Do you recall what you did differently this time compared with the last time when it used the general cospper clearance rule? I am asking dbecause I have tested this workflow using the Production Septemebr release and I created a copper clearance rule identical with the one you have created and I can get it to work but there is a catch. You cannot take advantage of the auto-complete that uses the quick-route diff-pair tool because this one can't use the custom clearance rules at the moment. I have assumed that maybe this is what you did the 1st time. If you route manually the diff-pair all the way then the custom clearance will be used otherwise it'll revert to use the general copper clearance. I am looking into fixing this issue as soon as possible.
I hope this helps.
Please let me know if there is anything else I can help you with.
Kind Regards,
Constantin Popescu
Principal Software Engineer
Message 6 of 16
Hi @aiolus2ZLRU,
I have played with the diff-pair router and the custom rules and you can use In Net Classes scope if you have a net-class that contains your diff-pair or all of your diff-pairs for both Object 1 and Object 2 or you can use In Diff Pair scope for both objects. Using In Signal will not work at this time because the quick-route diff-pair engine only uses one signal to get the clearance and the custom rules require 2 scopes (we can't use the same signal on both Object 1 and Object 2 scopes). I am looking into improving this behaviour right now. If you can use any of the above scopes that would help you circumvent this issue. Please see the custom design rules snapshot bellow:
Please let me know if there is anythign else I can help you with.
Kind Regards,
Constantin Popescu
Message 7 of 16
aiolus2ZLRU
I always use manual routing, but things are strange now.
Yesterday, custom rule for differential pairs failed on my laptop and desktop, and this morning it seems work as expected on my laptop. But now when I tried same things on my desktop, it still not work. Both computers run latest version of Win10.
I reopen a test project to try the differential pair routing on my desktop. I reload default design rule and add only 1 custom rule for clearance which resualt as below:
Space didn't change, only violation was showed.
Besides, when the design rule is work on my laptop, the meander is not work on differential routing.
Below is the software version on my desktop
If there is further finding, I'll update here.
Message 8 of 16
aiolus2ZLRU
Sure, I've tried In Netclass Scope but not work on my desktop as below.
it's really weird, I'll try again on my laptop.
Message 9 of 16
aiolus2ZLRU
I just find the point, the custom rule does not work when differential pairs are centralized.
Same custom rule, PairA won't affect by design rule, but PairB does.
Message 10 of 16
aiolus2ZLRU
Furthermore, I tried meander on differential pair and resualt as below
For centralized PairA, custom rule not applied, meander length 50mm is worked perfect.
For shift PairB, custom rule applied, but meander only work on single wire.
These are current findings.
Message 11 of 16
jorge_garcia
Hello @aiolus2ZLRU,
Thank you for reporting this. Our developers are already working hard to correct these issues ASAP. None of the custom rules will work currently for diff pairs but this is being addressed.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
Message 12 of 16
aiolus2ZLRU
That's ok, I can still use general design rule to get work done.
Wait for your update on custom rule, it will be more convenient if works.
Thanks.
Message 13 of 16
HelenChen-AutodeskQA
Hi @aiolus2ZLRU ,
Hope you have a great day.
Today the latest Production build is updated to 2.0.20460 with the fix about the issue you reported. Could you please upgrade to latest version to have a try? Thank you so much for reporting this issue to us.
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
Message 14 of 16
kyle_andersen
Hello all,
I am seemingly having the same issue.
Custom rule for width of the differential pair traces:
Custom rule for spacing of the differential pair traces (I tried both same signal and different signal versions):
The differential pairs are routed with 5 mil spacing instead of 6.7 mil spacing, as if the custom rule is overwritten by the global default spacing rule:
Thanks in advance for all the support!
Kyle
Message 15 of 16
jorge_garcia
Hi @kyle_andersen ,
The problem here is that the rules are mis-scoped. Every scope is composed of AND so what you are saying is if an object is in the DIFFpair TX_P, TX_N AND DIFFpair STUBRX_P, STUBRX_N ,etc. There's no way an object will be part of both the TX Pair and the STUBRX pair at the same time so your rules are effectively doing nothing.
The better approach would be to scope to a netclass. Try making a netclass and assigning all of your diff pairs to it. Now scope to the netclass
Give that a try and let me know if you continue to run into problems.
Best Regards,
Jorge Garcia
Message 16 of 16
kyle_andersen
Thank you Jorge! Assigning the nets to a net class and defining the copper width and spacing for that net class solved the issue.
