Copying 3D PCB component to normal design file
Previously (several weeks ago) when I uploaded a PCB from Eagle to Fusion 360 it appeared as a normal design file, which allowed me to left-hand-mouse-click and copy the complete PCB into another file which contained the enclosure and mechanical parts.
Now when I upload from Eagle it imports as a 3D PCB file and the left-hand-mouse-click-copy is no longer available.  How can I copy the complete PCB from a 3D PCB file into another normal design file to allow for mechanical design/integration.
Tony
In the 3D PCB- there is no "copÿ" option in the drop down menu.
s.kishore1998
Create a new design.
Click show data panel on the top left.
Fnd your pcb file and right click and select "insert into current design. "
Alternatively you could also create a new design and use "insert--> insert derive" to bring the outline or anything to your current design.
yqliu
Hi @Anonymous ,
Before we integrated Fusion electronics environment into Fusion 360, if you push a pcb from EAGLE to Fusion, you will get a Fusion document with PCB and mechanical parts mixed together. Now we put 3D PCB into a separate document to make it more flexible and stable. For example, you can insert the 3D PCB into different enclosures.
@s.kishore1998 's proposal is the correct way to combine a 3D PCB and the mechanical design into one assembly.
