Can't edit library in fusion 360
manish.ingale
manish.ingale
Hello sir,
We work in team with fusion 360 with 3 members. One the team member upload the library in fusion team account and added link from the library.io to all libraries. If another member from the team tries to edit library to added 3D packages in library make issues. Following image shown error to try edit library. Alos another person can not seen also 3D fiels added part.
Please help and suggest a solution.
edwin.robledo
Hi manish.ingale,
Your participation in the Fusion 360 forum is really appreciated.  Using your favorite browser, please log in to library.io using the same credentials you used for Fusion 360. Please add your other 2 colleagues to the managed folder which contains the libraries you are wanting to share. By adding them to your managed folder in library.io, they will receive an email notification, they need to login to library.io and accept the invitation.  Now they will be able to map 3D models to your footprints.
Please keep us informed of your progress.
With Warm Regards,
Ed
Edwin Robledo
Tech Marketing Manager
