Can I run Scripts & Add-Ons from Electronic Design?
jasonchildress1978
jasonchildress1978
I'd like to start automating some of my electronic design processes with python. But I'm having a hard time finding a place to start.
I turned on the Scripts and Add-Ins feature in preferences, but it appears that I can only use it in a regular 3D design and not my electronic design? The dialog can only be opened from the Utilities Tab (in a regular design) and its modal so once I open, I can't switch to my electronic design.
Is there currently a way to run python scripts in an electronic design to help automate my workflow?
jorge_garcia
Hello @jasonchildress1978 ,
I hope you're doing well. Currently, Electronics is not properly supported in Fusion Python API. There is some functionality available which is what the Ultra-librarian and SnapEDA plugins use, but there isn't much official documentation for using the Fusion Python API in Electronics. For now the recommended approach is to use the ULP language and scripts.
Fusion Electronics ships with several of these as examples. You'll find the documentation here:
https://help.autodesk.com/view/fusion360/ENU/?guid=ECD-AUTOMATION-CPT
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
jasonchildress1978
Thanks. I'll look into using a ULP script.
Are there future plans to support Python in electronics designs?
jorge_garcia
I hope you're doing well. I have added your comments to an existing ticket for getting Electronics into the Python API, it something we definitely want to do but it just hasn't been prioritized yet.
Best Regards,
Jorge Garcia
holla2040
I'd like to see if projects like these
https://github.com/ArchimedesCrypto/fusion360-mcp-server
https://github.com/Joelalbon/Fusion-MCP-Server
could connect to the future electronics API via MCP.
Then have an AI, like claude, pull the schematic parts, nodes and nets then crunch on optimizing brd parts placement with these criteria - minimizing board space, minimizing signal length, analog/digital separation etc.  I can see this happening once an electronics API exists and someone writes an MCP server for it.
https://www.anthropic.com/news/model-context-protocol
pal.szabo
Fully agree. We would actually do half the development for you guys, in the form of add-ins with an API access. I would love to see this prioritized.
Best regards,
Paul
