BASIC FEATURES DON'T WORK --UNLOCK
nnovotney
nnovotney
LOUSY IMPLEMENTATION--WHY???????????????
click on unlock
now check property
is quality control at AUTOCAD really this PATHETIC??
ok, unlock it myself
now  do this
do lock, FAILS:
Evert_2N3055
Works fine here.
Did you hold the shift to unlock as mentioned in the bottom of your screen?
nnovotney
Nope, there is no message there, it just fails to unlock.  There is a message LATER, after the click is executed--but you don't know it failed.
The failure is in the  hovering selection, when something is locked
There is some kind of logic modal bomb going on.
jorge_garcia
Hi @nnovotney ,
I hope you're doing well. Was this board outline linked to at 3D PCB? Board outlines that are linked to an assembly are locked and can not be unlocked by the LOCK command. Can you confirm if that's what's going on?
Best Regards,
​Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
