Attributes bug
Attributes bug
n.smithHJCP5
Attributes bug
n.smithHJCP5
This is a really specific bug report. Using 2.0.15291 . I feel like I would have encountered this before so it might be new to this version.
1. Editing electronics library
2. Open a device
3. Click a mapped package connected to the device. Then at the top bar click Device>"Attribute".
4. Click "New" to make a new attribute.
5. Now I want to make an attribute called "TOLERANCE". So I type the letter T. It autocompletes to "THERMALLOSS".
6. Fair enough, I'll just ignore the autocomplete and finish typing "TOLERANCE". However, now the "OK" is greyed out.
The same thing happens with the letter M with MAXTEMP. It look like these are the only two autocompletes that are stored.
I can type any other word just fine. If it doesn't trigger that autocomplete, then the OK button remains clickable. The workaround to this is I just copy and pasted the word "TOLERANCE" into the name to avoid triggering the autocomplete.
jorge_garcia
Hi @n.smithHJCP5,
I hope you're doing well.  Thanks for reporting this, I've added your thread as evidence to the ticket that was filed about this issue yesterday.
Thank you for bringing it up.
Let me know if there's anything I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
wleismer
I just ran into this same issue, so thank you for your post and workaround!
panpan_fan
Hi @n.smithHJCP5 @wleismer
I hope you are doing well!
Today we release Fusion 360 V2.0.15775 and this issue has been fixed now.
Please update Fusion 360 and have a try, thanks!
Panpan Fan
