Adding Via in Polygon causes airwire errors
erussellK6Q8Z
erussellK6Q8Z
I have added a polygon to my routed board which had no airwire errors. Adding a thermal via to the polygon instantly caused 100+ airwire errors to appear. Any idea why this might have happened? Deleting the via removed the airwire errors.
jorge_garcia
Hello @erussellK6Q8Z ,
I hope you're doing well. When that happens just refresh the polygon, this is a known behavior. Whenever a new object is associated with a polygon its airwires reset. Refilling the polygon will make those airwire errors go away.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
