Add harness drawing feature to fusion electrics design instead of only focusing on PCBs.
j_dommasch
j_dommasch
also, working with custom symbols in schematics seems unnecessary complicated, or is impossible, as
there is no means of just adding new symbols, without footprints, etc..
jorge_garcia
Hello @j_dommasch,
I'll send your request up the chain. Keep in mind Fusion is really designed and tailored to PCB design. Harness design is an electrical discipline as well but not directly related to PCB development. If I remember correctly you have another thread talking about components, I've put a response there for you.
Short term a library for wiring harness design might be a good solution.
Thank you for the feedback.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
wwfeldman
sorry
i must disagree
anything more complicate than the electronic version of "print my name is fred" needs some sort of wire harness,
or board to board connections, or wires to panel or chassis mounted components.  this is the gist of the one schematic multiple boards thread.
wiring harnesses aren't much different from plumbing. maybe that aspect from construction can be leveraged to electronics.
drewread
Agreed.. required for building electrical and mechanical assemblies.
