A few super annoying things with version 2702.1.58 arm64 (Native)
I've been staying away from here to keep my frustration to a minimum level.
I have collected tens, if not hundreds of minor bugs during the last couple of years, some have been fixed, most not. But I'm just not going to the trouble of reporting them, as I know they will just be ignored, as usual.
But a few things are driving me nuts daily, so I HAVE to bring them up.
1. Not a new bug in this version, but the tGlue layer gets activated randomly when I switch from schematic to board. I turn it off, and a little later, it's activated again. EXTREMELY annoying.
2. The new "Start-up experience" sucks so bad. It just dumps you in a totally unsorted mess of icons for projects, boards, schematics and 3dboards. With hundreds of projects, this is just insane.
If you try to escape that by selecting "Projects", it gets slightly better, and you get a "file manager" style list of projects and folders. Basically like the data panel was before, but extremely slow, because it now seems to fetch everything from the cloud and browsing and folder selection is at snail speed.
Also, WHY is there a drop down arrow for empty folders? And then showing "No subfolders".
There is a preferences option to set Fusion back to the original "Default Design Type".
It works, ONCE after you start Fusion. As soon as you close your project, you're dumped back into the new horrible "Home" page.
3. And while we're at preferences, the Defaults for the board editor grid don't 'stick'.
Every time, I have to open the grid window and click the "Default" button manually.
This bug has been around for ages.
4. When I click the Grid icon at the bottom, the window that is opened will has it's buttons outside my screen., because the window opens centered vertically on the icon. And as the icon is usually almost or at the bottom of my screen, half of the popup dialog is outside the screen.
This should be changed so the window will be restricted to the size of the Fusion Window.
Or even better, aligned to the bottom of my screen.
5. Very often the data panel are replaced with this:
This only happens after I have opened a project file, making it impossible to open more than one project at a time.
6. Airwires are STILL disabled by default in the Selection Filter, making it difficult to route tracks.
I have to re-enable it every single time I open my board file. Not just once, for the project, but EVERY SINGLE TIME I OPEN THE BOARD.
I don't know who came up with this crazy idea to disable airwires (which were enabled in the old days), without an option to set it on or off by default.
When you do changes like that, please KEEP the existing functionality and make any new functionality selectable, if anyone would like to have it that way.
DON'T BREAK THINGS!
As I've said to many times before, it would be SO nice, if you would FIX BUGS first, and add stupid new useless features later.
