Greetings!
It's been 5 horrible days for me, full of frustration and irritation and I hope someone can help me end this period.
I try to complete one simple task - import a small project, made in Autodesk Eagle 9.6.2 into Fusion Electronics.
Linking/uploading the schematic and the already routed in Eagle PCB went with no issues. The problem started, when I tried to push the PCB and make a 3D model. All 3d models for parts, including simple and basic ones like C0603, C0603k, capacitors and R0603 resistors are missing! Here is what I tried to solve the issue:
• Replaced , (by selecting and using Replace command) all components, one by one with the same component from Fusion 360 rcl.lib or Resistor.lib and Capacitor.lib, where such components have 3D models attached (that was checked multiple times by opening the libraries for editing).
• Uploaded my own rcl.lib and added 3d models in it for the needed parts by generating. The adding went with no issues - after reopening the library, the 3d models were correctly attached to footprints.
In either of the described above procedures, no 3D models were generated when pushing the board to 3D model.
The only way I managed to make a single, (and very lucky) capacitor have its 3d model was by assigning it manually with the command "Add custom 3D model".
I kindly ask if someone could walk me through the basic steps of importing a PCB in Fusion 360, from EAGLE and (auto)update/link the missing 3D models to packages, which have standard names. All video tutorials I watched so far are outdated and describe the procedure before integrating Eagle into Fusion.
My other question is if there is a way to update/replace all components already used in a design at once, with components with the same names, but located in another library? (So far I've been doing this by replacing the library's name inside the *.brd, *.sch files, which are text files).
Thank you!
