Using a custom stock for manufacture
u1
Observer Observer
Message 1 of 12
u1
Observer
Observer
So I have a type of hex nut shape without the threading (see shape), when I use this part in manufacture, the only stock that I can use is either square, cylindrical or a hollow hex bar. I want to model the stock as a solid hex bar and machine it down to the desired shape. Please help
Replies (11)
Message 2 of 12
seth.madore
To do so, you need to create a solid model of the stock, and then select "From Solid" in your setup (selecting that model, of course)
Seth Madore
Message 3 of 12
u1
Observer
Observer
I understand that I can create the part from a solid hex
Isn’t it possible to use a solid hex for the stock and then just machine
the specific part out, because it’s much easier that way
Message 4 of 12
seth.madore
There is no "Hex" option in the stock options, just Box, Cylinder and Tube
Seth Madore
Message 5 of 12
u1
Observer
Observer
so I have to model the part from the Hex part
Message 6 of 12
seth.madore
Step one: create your model, the one you're machining
Step two: create a second model, one that represents your stock shape (in this case, a Hex)
Step three: Create a Setup, selecting your actual model in the Setup
Step four: On your Stock selection, select the model of the Stock that you created
Seth Madore
Message 7 of 12
u1
Observer
Observer
Should the hex model be extruded or only the flat shape.
And should the 2 models be on the same design sheet
Message 8 of 12
kellings
Yes. You need to have an 3D body and your part needs to be inside of that 3D body.
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
Message 9 of 12
u1
Observer
Observer
I have done it, but it then takes both parts and rotates around a random
point
Message 10 of 12
kellings
Would you be able to upload your file here? You can either right click on the file in the data panel and choose share link and then make sure to tick the option to allow the file to be downloaded, or export the file as a .f3d Fusion archive file and attach that here. Thanks, Kevin
Kevin Ellingson
Message 11 of 12
u1
Observer
Observer
I will send you the file shortly. Thank you soo much
Message 12 of 12
kellings
Hi @u1 Did you get a chance to share that file so we can help you get this figured out?
Kevin
Kevin Ellingson
