Tubing Specs
Tubing Specs
Message 1 of 22
Tubing Specs
Are there Tubing Spec Catalogues, for items such as Swagelok Fittings, to be able to route tubing as you would Piping in AutoCAD Plant 3D?
Replies (21)
Message 2 of 22
Tomislav.Golubovic
Have you checked the App Store?
Message 3 of 22
  Thank you, Tomislav.Golubovic… I did try the Autodesk App Store, but could not find any Tubing Catalogues...
            sincerely,
                              Patrick
Message 4 of 22
Tomislav.Golubovic
You'll have to get data sheets from the vendor and then make your own catalog, or employ someone to make them for you
Message 5 of 22
There are tubing catalogues available from the content store:
https://apps.autodesk.com/PLNT3D/en/Detail/Index?id=4047113657445692814&appLang=en&os=Win64
These are well equipped but don't include the swagelok compression fittings.
I had to build a custom catalog for the swagelok compression fittings, but this wasn't too taxing as Swagelok provide a wide range of 3d models on their website.
Cheers,
Rob.
Message 6 of 22
ZZikic
Hi Pat,
Yes, the tubing content pack is a good place to start.  There are however, excellent 3D neutral files available on the Swagelok website.  You can download what you need and use the PLANTPARTCONVERT command to create your own Swagelok fitting template for use in Plant 3D Spec Editor to create a Swagelok catalog with fantastic results.
Best regards,
Zeke
Message 7 of 22
Thanks for the message, Zeke... Sorry that I have taken so long to respond. I have been side tracked with other work, than AutoCAD Plant 3D... I will look into this more when our workload permits...
              Pat
Message 8 of 22
KSchieck
Can you share your files?
Kevin
Message 9 of 22
ZZikic
Hi Kevin,
 Sorry, unfortunately for legal reasons I'm unable share company content with any outside entity or non-partner.
However, I could point you in the right direction and answer any questions you may have.
Best regards,
Zeke
Message 10 of 22
tstorzuk
@ZZikic
I'm interested in how you made your Swagelok fittings for Plant 3D.
Do you have a step-by-step procedure that you used (that you can share)?
What type of ends did you use for the press-on (Swagelok Tube Fitting) type ends?
What did you use for bends? Custom diameters or standard ones?
Message 11 of 22
KSchieck
I'm interested too, it's a time consuming procedure to download all the swagelok models!
Message 12 of 22
ZZikic
I didn't find it terribly time consuming.  Swagelok is quick at sending your requested models from their 3D CAD site.
I typically use STEP file format and import all the sizes I need.  I tend to stay to the more commonly available sizes.
For compression tube fitting ends I treat them as SW ends
1/8 (usually I omit this size)
1/4
3/8
1/2
5/8 (usually I omit this size)
3/4
1
1 1/4 (usually I omit this size)
1 1/2
2
  1. Import the STEP models into a drawing session.  Explode them and recreate blocks for each size.  I recommend to use the part number.  (For example SS-810-9 for 1/2" union elbow)
  2. Change to wireframe (it is easier to see and select the ports)
  3. Run PLANTPARTCONVERT.  Select the block. Follow the prompts to select each port and it's direction. Clicking Accept each time.  When all ports are selected click Exit.
  4. Save the drawing session as for example SwagelokCatalog.dwg
  5. Start Spec Editor.  In your Swagelok catalog Create New Component using Custom - AutoCAD DWG Block based graphics.  For each new size created Select Model... and browse to the SwagelokCatalog.dwg and select the appropriate block. Click OK.  Fill in all other required field as you normally would.
Best of luck!
Zeke
Message 13 of 22
ZZikic
Alternately,
I prefer for performance reasons to use Python scripted components whenever possible rather than converted blocks.  With a bit of Python knowledge one could implement custom Swagelok fittings like this.
Message 14 of 22
julie_havard
Did you do it for all?
Message 15 of 22
ZZikic
Only for the commonly used components in our company's SS tubing spec.  Couplings, elbows, tees, and a couple valves.
Message 16 of 22
julie_havard
Can you send me what you did??
Message 17 of 22
ZZikic
Hi Julie,
I outline in the above chat how these fittings can be added using the PLANTPARTCONVERT method.  For Python it is just using rectangles and cylinders to build each fitting.
Best regards,
Zeke
Message 18 of 22
tstorzuk
I find that the downloads from the Swagelok site are stupid slow.
I requested a batch of 308 files this morning at 7:22am. It's now 10:43am and they still haven't shown up in my email. You must be lucky in your downloading times from Swagelok.
Message 19 of 22
ZZikic
308!!!??? Perhaps try requesting smaller batches at a time?  There may be a size constraint.  I've always requested maximum 1 or 2 dozen at a time.
Message 20 of 22
tstorzuk
Yes, 308. All of one category of items;
That's not a lot of items, compared to some of the categories. For example, the one below has 1316 items within this single category;
And that's still not the maximum number per category. You can download a maximum of 500 CAD files in one request. So 500 is the size constraint.
If I make smaller requests, it would take forever to download their entire CAD catalogue.
