Tinkercad Import a Fusion File
heyrobert
heyrobert
Me again! I recently discovered Tinkercad... and I see that it's owned by Autodesk as well. Tinkercad has a Sim Lab... can you import Fusion 360 models into it? I see that you can import Tinkercad models into 360. I'm surprised something as simple as Tinkercad would have the ability to simulate gravity, etc., but 360 does not. Thanks!
dan.banach
Hi @heyrobert
I moved this topic to it's own post. In Tinkercad, you can Import; STL, OBJ and SVG files.
Hope this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
heyrobert
Thank you!
