My goal is to create single line text on a 5" design. Here are the steps I have taken: Sample sketch listed below:
Open new sketch (rectangle)
Enter text (Simplex.shx)
Explode text
Changed constraints from green to blue
Selected rectangle and text and extruded
Single line text disappeared until I clicked on sketches to view text
Went straight to manufacture
Setups - selected origin bottom left - selected body - clicked OK
Selected Cutting
Selected Tool (Hypertherm 45)
Selected Geometry
Highlighted each part of each single line text along with rectangle box
Selected Passes
Changed Compensation to Center
Selected Linking
Unclicked Lead-In and Lead-Out Radius
Set Pierce Clearance to 0
Selected OK
Much to my surprise, it worked this time.. As you review this, do you have any concerns as to the way I did it. I believe my problem may have been in the Geometry section. Two things, the Youtube video from 2019 referenced double clicking each letter to select the entire letter. This did not happen and I had to select each segment of the letter individually. Second, the newer version of Fusion 360 gives three choices in the Geometry section:
I did not choose any of them this time as I normally would when creating a sketch for g-code. I have been working on this for a couple days and it finally worked. Look forward to hearing from you. Thanks
