Simulation CNC Machine Updates UMC 350?
SuncoastTechnicalCollege
Message 1 of 9
Will you be adding the new UMC 350EDU  5 axis machine as a simulation machine.  90% of these are being sold to schools - and have been renamed with EDU
also are you adding CNC lathes?
CNC Machinist Education Network
https://www.youtube.com/c/CNCMachinistEducationNetwork
Accepted solutions (3)
Replies (8)
Message 2 of 9
dan.banach
Hi @SuncoastTechnicalCollege
I'll ask the team and keep you posted.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
Message 3 of 9
seth.madore
CNC Lathes will make an appearance when we actually are able to properly support the simulation of lathes and turn/mills. It's on the "to-do" list, but still very much a work-in-progress
Seth Madore
Message 4 of 9
tim_paul
@SuncoastTechnicalCollege I just made the request. BUt, if you need something sooner there are good machine builder videos to make a sim model from the downloadable models.
Message 5 of 9
excellent thanks. We just ordered UMC 350 so it will be awhile but we can play in the mean time
Message 6 of 9
jake7YK82
Also just got a 350 hd in house. Looking for the simulation config file as well as a post. Any help is appreciated. Thank you!
Message 7 of 9
Tim told me its definite in process for simulation.
I do need to look at which post and switches are needed.   I saw UMC 500 and 750 selection in posts for next gen , But not sure about this.  we get our machine on Jan 18th
Message 8 of 9
The simulation machine is in the Fusion Library online.    The post assigned is the regular NGC.   There is a selection box for diferent UMC machines in Post - But I need to see if UMC 350 is added
Message 9 of 9
jake7YK82
Thank you, I have set up the machine and using the Haas NGC Post. Appears to be working correctly!
