renew issue
renew issue
ginelabadiu
renew issue
ginelabadiu
I'm eligibile but I can't restart access.
dan.banach
Hi @ginelabadiu
Can you please try the following.
  1. Log into the Autodesk Education site
  2. On the Fusion 360 product card click "Get product"
  1. Then click "ACCESS"
  1. Sign out and back into Fusion 360
Let me know if this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
dan.banach
Hi @ginelabadiu
Looks like you posted this same question in a couple posts. Let's use this one. the other was solved for a different person.
To confirm, when you do the following, nothing happens?
Renee Autodesk Education Eligibility
  1. Navigate to the Get Products page.
  2. Under the Get Started section click Sign in and log in with your Autodesk Education credentials (same email and password you log into Fusion 360 with).
  1. Click Renew Now or Renew Access in the personalized banner notification.
Thanks for your patience.
-Dan
Dan Banach
dan.banach
Hi @ginelabadiu
I learned that some education accounts are having the renew issue like you documented. The team is working on this issue, but I don't have a timeframe for the fix.
In the meantime, can you try to create a 30 trial of Fusion 360 using your same email address that you're logging into Fusion with?
Please let me know if this works for you. I'll let you know when I find out about the fix.
-Dan
Dan Banach
