Load projects from a360
I'm trying to load models from a360. For each hub, I get a list of all the projects with all the items, however, for some of them, I get a 404 when trying to load them, even though I can see them in a360, any idea why this may be happening?
StephenPreston
Hi ainaker,
Can you elaborate on exactly what you're trying to do (API calls made and errors received) - ideally providing some sample code?
At the moment, in order to view a file using the API, you need to explicitly translate it to SVF - even though A360 has already translated it once in order to allow the model to be viewed in A360. This is a quirk that will be fixed soon.
And perhaps you could test using this sample to see if you still have a problem - https://github.com/Developer-Autodesk/model.derivative.api-nodejs-sample.
Cheers,
Stephen Preston
Autodesk Developer Network
