Fusion 360 Archived and Deleted Project, Subsequent Created Project unable to Invite Members
mae-cae1
mae-cae1
I have archived and deleted a project. Subsequently, all the projected created unable to invite members. Could anyone advise why? The created project icon has changed (See below). The first one 21S2MEW11ThuG5 is the original one which is working normally (before archived and deleted). The 2nd one 21S2MEW11ThuG6 is the newly created project doesn't allow me to invite members. It only prompts "manage in fusion team". How do I get back the original project icon? Thank you.
dan.banach
Hi Teo,
We recently introduced Folder-Level Projects for Education accounts, and this is now the default project type within Fusion 360.  You can invite members to the Project in Fusion Team. You can get to Fusion Team from within Fusion 360 Data Panel by clicking on the Manage in Fusion Team as you showed in your image or click on Open on the Web. Or go to https://login.autodesk360.com and log in with your Autodesk ID. Here is a link that will take you to an article that explains Folder-Level Projects and Permissions.
Let me know if this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
mae-cae1
Thank you very much for your reply.
How do I change the default project back to original close project?  Because this is currently the most convenience way to invite members.   Thank you.
MattPerez314
@mae-cae1 I think with this new setup there are no longer open, closed, private project types, just folder level permissions.  @dan.banach is that true?
dan.banach
Hi Teo,
Currently, you can't change a Folder-Level Project to a different type. To create legacy project, do the following.
  1. Log into Fusion Team by going to https://login.autodesk360.com
  2. To show a list of projects on the Fusion Team, click the Fusion Team danbanach_0-1644940622576.png   icon in the upper-left corner of the browser.
  3. On the right side of the screen click on danbanach_1-1644940660150.png.
  4. Type a name for the project and then click, shown as step (1) in the following image.
  5. Select the Project’s Security Type from the pull-down list, shown as step (2) in the following image.
    1. Open: Any team member can access this project.
    2. Closed: Only invited members can access this project.
    3. Secret: Only invited members can see this project.
    4. Folder-Level: A secret project with granular permissions for each folder (default)
Note: Once a Folder-Level project is created, this project’s security type cannot be changed.
  1. If desired select an avatar for your project, shown as step (3) in the following image.
Click Create Project, shown as step (4) in the following image.
Hope this helps.
-Dan
Dan Banach
