Differant colours when patching.
charlescooke58
Message 1 of 16
charlescooke58
Hi everyboby can you tell me why my image comes out in differant colours and how do I get it the same colour?
Cheers Charles.
Replies (15)
Message 2 of 16
kellings
Surface bodies have two colors. A front or normal side, and a backside. Solid bodies are colored differently, either by the material or by applying an appearance color.
I can't tell entirely if you you have a mix of solids and surfaces. In the component you have expanded, I can only see surface bodies. You can try to use the stitch command from the modify menu to turn everything into a solid. I can't guarantee the results without seeing the rest of the data in the file. If you want, you can post the file and let us know what you want you final result to be.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
Message 3 of 16
charlescooke58
tThanks for Kevin, I did it differant methods, I will see to get the file to you. So I click file, export and then drag and drop file, I think I did it. Sorry I havent done this for a while.
Message 4 of 16
charlescooke58
I think this is what you need.
Message 5 of 16
kellings
Hi @charlescooke58 My apologies. I started working on this and then got distracted and it fell off my radar.
What is your goal for this project? To end up with a solid when you are done? I tried some things like copying all of your surfaces to a common folder and then stitching them together. They didn't stitch at the default tolerance. Most of the seams showed in red meaning they wouldn't be closed when the stitch command was completed.
Let me know your goal for this design and we'll see if we can come up with some ways to get you what you want.
Kevin
Kevin Ellingson
Message 6 of 16
charlescooke58
Hi Kevin.
My goal is to build a model boat out of this as a project. The skin is used
to cut out the formers, but I agree parts are not matching as I would like
but I have cut the formers. The different colours is not an issue other
than I would like it looking the same and I notice this happens when I am
lofting patching etc everything is grey on the outside and gold inside,
except a piece will have gold outside. I'm just wondering if I am doing
something wrong. I notice also the formers still show through the skin
after the split body.
Cheers Charles
Message 7 of 16
dan.banach
Hi @charlescooke58
Have you tried to apply an Appearance (press the A key) and then drag an appearance onto a component  or an individual faces as shown in the following image?
Does this help?
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
Message 8 of 16
charlescooke58
Hi Dan.
I just want to know why when patching ,lofting etc. The usual is grey on the outside and gold on the inside. But one part is opposite, those are the 2 colours that are associated with these actions. just wondering if maybe my actions are wrong and is there a way to get them same other than the method that you mentioned, which I am aware of. If it is just what it does then I just change the appearance way.
Message 9 of 16
dan.banach
Hi @charlescooke58
You may be seeing the faces with a different light applied to them. When you change the viewpoint, only your perspective is changing, the bodies stay constant to their current location. Below is a screen capture of the same surfaces, just from different perspectives.
Does this help?
-Dan
Dan Banach
Message 10 of 16
charlescooke58
when in surface mode and I patch, loft, sweep there only two colours, Gold inside and grey outside on my computer, even when I watch videos of how To's I see the same thing. I have also just used the apearance method to colour the differant components differant colours for identification purposes, But when I finished it changes everything to the same colour.
Message 11 of 16
dan.banach
Hi @charlescooke58
Can you share a video that shows the different colors of the faces?
To automictically show components in different colors, you can use the Component Color Swatch option. This option is located on the lower-right corner of the screen and click on the Gear > Component Color Swatch
Does this help?
-Dan
Dan Banach
Message 12 of 16
charlescooke58
Hi Dan sorry i didn't realize you responded. I don't know how to take a video, but I have taken another Screenprint. Now I applied appearance to the drawing and it appears that the gold does not change color only the grey which says to me there is something wrong with my drawing. The hull and the keel was grey and the colors applied outside but the upper deck and pilot the colors were applied to the inside.
Message 13 of 16
dan.banach
Hi @charlescooke58
Can you please attach an updated .f3d file, and we’ll look at the file.
-Dan
Dan Banach
Message 14 of 16
charlescooke58
Hi Dan here is the updated file.
Message 15 of 16
dan.banach
Hi @charlescooke58
Good news. I was able to duplicate your issue. By selecting the Reverse Normal tool, it shows the gold faces that displaying the negative side of the surface. If desired, you can unstitch the surfaces and change their normal individually.
Does this help?
-Dan
Dan Banach
Message 16 of 16
charlescooke58
Thanks for that Dan now I know because gold does not change colour only grey, I take it that to "reverse normal" a component must be all same color otherwise I must unstitch and get it same color.
