Can't Sign Into Fusion 360 via a Browser
antonio.akue
antonio.akue
Having log in issues, with the new update
when I open the application and click sign-in, fusion can't open my web browser
I'm using a MAC - OS Venture
any way around this ?
Replies (8)
dan.banach
Hi @antonio.akue
Sorry that you're having this issue. Have you asked your IT Admin to add the domains that Fusion 360 needs to be allowed? See this Ports and Domains article
Unrestricted access to the following domains (the following domains have anonymous access through the proxy server for installation)
  • *.autodesk.com
  • *.autodesk360.com
  • *.google-analytics.com
  • *.akamaiedge.net
  • *.appstreaming.autodesk.com
Also, can you try to log into Fusion from a home wifi?
Please keep us posted.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
antonio.akue
I've added this to my network proxies and the problem still occurs  and i've changed the port to 80 and 60
dan.banach
Hi @antonio.akue
Can you confirm that all the domains in the Ports and Domains article are on your allowed list?
-Dan
Dan Banach
antonio.akue
I've pasted the following below, in the bypass proxy setting :
*.autodesk.com
*.autodesk360.com
*.akamaiedge.net
*.accounts.autodesk.com
*.fusionapi.autodesk.com
*.clientstream.launchdarkly.com
*.mobile.launchdarkly.com
*.notifications.api.autodesk.com
*.services.autodesk.com
*.ui-dls360.autodesk.com
*.autodesk360.com
*.amazonaws.com
*.akamai.com
*.akamaitechnologies.com
*.uploads.protolabs.com
*.tracepartsonline.net
*.mcmaster.com
*.s3.amazonaws.com
*.s3-accelerate.amazonaws.com
*.autodesk.com
*.api.autodesk.com
*.www.google-analytics.com
*.www.googletagmanager.com
dan.banach
Hi @antonio.akue
Can you try to join the Wi-Fi via a hotspot from your phone, and then try to log into Fusion and see if this helps? This will help determine if this is a network setting. I'll also ask our engineering team for their input.
Thanks for your help in figuring out what is going on,
-Dan
Dan Banach
dan.banach
Hi @antonio.akue
Can you please add the following URLs to your allowed list:
*.autodesk.com
cdn.accounts.autodesk.com
a.wa.autodesk.com
smetrics.autodesk.com
c.wa.autodesk.com
auth.autodesk.com
native.auth.autodesk.com
developer.api.autodesk.com
https://profile.autodesk.com
https://api.userprofile.autodesk.com/userprofile
authn.autodesk.com
-Dan
Dan Banach
dan.banach
Hi @antonio.akue
I wanted to  check-in and see if adding the new URLs to your allowed list, solved the Sign In issue?
If the issue still exists, please collect and send us the Fusion 360 log files.
-Dan
Dan Banach
dan.banach
Hi @antonio.akue
Were you able to Sign into Fusion? If so, do you know which URL was preventing you from signing in?
-Dan
Dan Banach
