3D models not showing when importing Tinkercad circuits for PCB design
david.bartoli
Message 1 of 10
david.bartoli
Hi All,
Currently, with the students, I generate circuits on Tinkercad and send them to Fusion 360 electronics to create the PCB. So we can manufacture the PCB and build a housing around it.
However, recently, I found that the components are not showing the 3D models when I push the design to a PCB 3D view. I have updated the libraries multiple times, but they cannot show.
Is there a fix to this, as it is a great feature for developing the housing of the PCB? I have attached some photos below of the situation where the link to the 3D model is not working. The image with the components attached is the outcome a few months ago where the components would generate.
Thanks for any support or ideas on fixing this
Replies (9)
Message 2 of 10
dan.banach
Hi @david.bartoli
Thanks for the message. Can you confirm the version of Fusion that is installed? In Fusion, on the top-right corner click on the ? > About.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
Message 3 of 10
david.bartoli
Hi Dan,
I am currently working on Fusion 360 2.0.17721 x86_64
Thanks for your support
David
Message 4 of 10
dan.banach
Hi @david.bartoli
Thanks for reporting this issue. The engineering team was able to reproduce this issue and are working on a solution. I'll keep you posted.
-Dan
Dan Banach
Message 5 of 10
david.bartoli
Hi Dan,
Thank you for the update. I appreciate the work you are doing to solve the issue.
Message 6 of 10
dan.banach
Hi @david.bartoli
The team made a change to the library. Can you please try to open your Tinkercad PCB file in Fusion and let me know if you have success.
-Dan
Dan Banach
Message 7 of 10
david.bartoli
Thanks for the quick turnaround.
I updated the library, and when I pushed the PCB design to a 3D model, a few components of 3D models were shown. For other components, I had to right-click in the 2D PCB screen and click 'replace' to manually change the 3D model to be shown.
Ideally, these should automatically make the process for students more streamlined.
Message 8 of 10
dan.banach
Hi @david.bartoli
Thanks for the update and for retrying the workflow. I'll pass this information onto the engineering team.
-Dan
Dan Banach
Message 9 of 10
dan.banach
Hi @david.bartoli
The engineering team just pushed a new library. Can you please retry to convert your Tinkercad circuit to Fusion and let us know if you have success.
-Dan
Dan Banach
Message 10 of 10
david.bartoli
Hi Dan,
Thanks for this I just tested this and got the 3D components to show in TinkerCad. I appreciate the work you and your team have put into getting this working again.
Best regards
David Bartoli
