Zip Tie Tunnel
Zip Tie Tunnel
woddy56
Zip Tie Tunnel
woddy56
Community Visitor
Community Visitor
I have a plate but I would like to be able to insert a zip-tie tunnel so that when I install the board you can't see the zip-tie that is holding the plate in place. The plate is printed to be 1/2 a centimeter thick.
wersy
Like this?
wersy
@woddy56
I would like to know if my suggestion is what you wanted.
I used a similar method 13 years ago on a printer I designed myself. However, the cable tie comes out at the bottom.
If it works for you and you have no further questions, please be so kind and mark it as solved.
