Youtube Channel Fusion 360 Tips
Please check out my Youtube channel will have machining videos and Tutorials on Fusion 360
https://www.youtube.com/channel/UCtrJydMCleu7tw5JQGGzRKA?sub_confirmation=1
brianrepp
Welcome to the Fusion community, these are great!
Thank You! I'm new to whole Youtube channel but I will get continue to get better as time goes on!
daniel_lyall
@Anonymous here is my channel there is some tips in there for what I just posted on your channel, I do router work so it is going to be a bit diffrent.
https://www.youtube.com/channel/UCuKkujqPgtKixzAdFDHjzJA
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
I should have added that makes the bodies first then make them as components after I model everything.
daniel_lyall
dont do it that way ever do it straight out as a component, if you keep the sketch and body togetter in a component, you can just insert it to a sketch that you have already done then if there is a mistake in it all you will need to do is fix the master file then any instance you have of it will update, other wise you will have to delete it in every file you have put it in.
also you will wont to model a vice's on the table that works the vices will need to be a sub component. it is the one best practise there is at this time that will not change.
it's just a better idea than converting a model you lose to much ablity to change stuff. all the other higher than me fusion members do it this way.they can't be all wrong sinces ADSK did give them A reward.
Daniel Lyall
The Big Boss
Mach3 User
