Yellow line in sketch
jdaues
jdaues
Why is one line yellow?
My goal here is to create a 2-dimensional surface from which I can get the calculated area
billbedford
This line was projected from something you've deleted.
TrippyLighting
The line is yellow because you projected it into the sketch from another sketch or the edge of a solid, or surface geometry, that was located earlier in the timeline. That isn't a recommended workflow!
Now the projection source is lost.
You can fix that:
Here is a link to a blog post that describes the process.
jdaues
Where is that popup menu coming from?
TrippyLighting
Right-click on the sketch in the timeline.
If you have such questions, I recommend you go through one or more of the free tutorial courses Autodesk has created to help new users.
Those can also be accessed through the help menu in Fusion:
