Wrong drill size tapped hole
maartenF74UH
maartenF74UH
Hello, fusion is giving me the wrong drill size for M10, should be 8.5. Anyone else having this problem?
jhackney1972
If you wish to change the value you can edit the tapped hole database.  Go on the internet and search for where Fusion stores the database tables.
John Hackney, Retired
maartenF74UH
I never had this problem before, been using fusion for years.
bwalker145
Here's what mine shows with the same selections:
maartenF74UH
Mine did that before, not anymore 😞
bwalker145
That's an odd one.
Maybe try to reinstall, or at least repair install via Service Utility?
Are you on the latest version?
maartenF74UH
That did the trick! Thanks
