Wrapping text on a curved object
leoNPC9V
Message 1 of 11
leoNPC9V
Hello 🙂
I have designed a coffee cup in fusion 360 for 3d printing and I am wanting to add text imbedded on the side of it. The problem I am running into is that the cup is a cone shape and the emboss tool is not working. The text does not follow the curvature of the cup.
I have tried a few videos on youtube but I am still getting stuck. Does anyone know how I can do this?
Replies (10)
Message 2 of 11
CGBenner
@leoNPC9V
Hello and welcome!  I've moved your post here to the Design forum as it is more of a "how do I?" type of question.  Fusion Support is used more for system issues or bugs.  Good luck with your question!
Chris Benner
Message 3 of 11
TheCADWhisperer
@leoNPC9V
Hint: Because you are wrapping to a conic - you will need to use Arc Aligned Text.
https://www.youtube.com/watch?v=562qG95-RVg
Tip: Are all of your sketches fully defined?
Message 4 of 11
g-andresen
First you need a path on tangent plane
watch my screencast Text around cone
günther
Message 5 of 11
Warmingup1953
You'll need to create an Arc on which to place your text. Here is an excellent tutorial by YouTuber Kristian_Laholm.
Emboss Text on cone
Message 6 of 11
laughingcreek
@g-andresen - what does the tangent plane do for you?  you still have to put the text on an ac path.  is there something about the tangent plane vs just a standard plane that makes the arc easier to figure?
Message 7 of 11
g-andresen
The difference is particularly more clear at larger slope angles
günther
Message 8 of 11
laughingcreek
all I see is that your using the wrong sized arc.   adjusting the arc will make them both look the same.  is there something about the extra steps of using the tangent plane that makes the arc radius easier to figure?
Message 9 of 11
TheCADWhisperer
I would use plane tangent to the cone.
Message 10 of 11
CGBenner
@leoNPC9V
Did the information provided answer your question, or do you still need help with this?
Chris Benner
Message 11 of 11
leoNPC9V
Hey everyone,
Thank you all for your help and solutions. I ended up figuring out how to make an arc on the tangent plane and then wrapped the text around the cup. Thanks again 🙂
