wrapping a sketch
wrapping a sketch
jeph00
wrapping a sketch
jeph00
See attached part - Is there anyway to wrap that sketch around part and extrude it as a cut into the part and creating that path?
  • wrap
daniel_lyall
https://www.autodesk.com/products/fusion-360/blog/august-2020-product-update-whats-new/
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
daniel_lyall
http://help.autodesk.com/view/fusion360/ENU/?guid=SLD-EMBOSS
Daniel Lyall
The Big Boss
Mach3 User
jhackney1972
After you read the attached help, you will have your model to look at.  It is attached, the cut is .125 inch deep.  Please note, the cut is perpendicular to the surface so the groove gets narrow as it goes deeper.  This may not be what you want.
John Hackney, Retired
jeph00
Good evening to you sir, thats exactly what I was after.
I attached my part again. This time I need help with machining this contour on a mill/turn center. Can't seem to be able to select the correct face/pocket to get it machined with a 3/8 flat endmill. Any idea?
daniel_lyall
@jeph00 Try with the wrap toolpaths.
Daniel Lyall
The Big Boss
Mach3 User
