Good Evening Guys,
I was hoping to get some guidance on over coming a road block which i'm facing with my design.
Road Block:
Don't know how to wrap my 2D sketch on the 5 surface of a cube, aka box.
Context:
I have create a box and want to add some art work on the box surface to make it look nice.
The art work is in an SVG file which i have imported on to 1 surface of the box.
Now i want to "bend" the SVG on the edge of the box, so that there is a continuation of the line from the top surface of the box to the side surface of the box.
Below is some images that might give some more information of what i'm trying to do.
I have seen a few you tube videos on how sketch can be projected on curved surface but tried to do it on 90deg surface but no luck....
I also tried the method explained by jhackney1972 on this tread How to project (or mirror?) a sketch to another plane/axis? - Autodesk Community - Fusion 360 but wa...
hence have reached out from some guidance on how to wrap a 2d sketch on a box surface.
Please can you advice and guide me to solving this road block.
