workflow off for sketch etc.
conjured2018
conjured2018
I open a .DXF  and then create component seeking to put all work under component. but the original image fades out and I cant see it to trace or sketch parts of it.
1> open file
2 create component
3 cant see original file
jeff_strater
by importing the DXF first, it is not a member of the component you created.  Instead, created the component first, then use Insert DXF to add the DXF to that active component
Jeff Strater
Engineering Director
g-andresen
your history is not enabled!
günther
